Replaced Relay
Old Dec 11, 2017 | 08:44 AM
bosborne3562's Avatar
Default Replaced Relay
Replaced starter relay & it still doesn't start so my husband tried to pull start a couple of times. After that tried the electric start again & it tried to start but went back to making a screeching noise but still tried to start.
Old Dec 11, 2017 | 09:21 AM
Make sure the battery is ok as even a new battery can drop under a load. You can load test one with a meter as this site shows.https://www.batterystuff.com/blog/ho...ry-is-bad.html If the battery checks out ok,the screeching could be from a worn one way starter clutch depending on which model you have.
Boxertim
Oct 30, 2016 10:18 PM
CobraGT40
Aug 28, 2016 04:44 PM
mikieveee
Jul 22, 2016 02:40 PM
06cumminsman
Jul 21, 2016 02:17 AM
