2001 yamaha raptor 660
Old Apr 19, 2018 | 06:48 PM
Tyler Slaght's Avatar
Default 2001 yamaha raptor 660
The piece im not sure of
So im currently putting my 2001 tranny back together stock, and i was putting the cases back together and this piece just appeared on my desk, and im not sure what it is. I dont want to continue because it is obviously for something. Anyone that could let me know would be greatly appreciated.. thank you in advance 😃😃
Old Apr 22, 2018 | 02:31 AM
No experience of Raptors at all, but half of that collar shows signs of rust, so it goes on a shaft that runs from inside to outside of case, almost certain that collar will run in an oil seal. So either on crankshaft behind a pull start (if it has one,) or on output shaft from gearbox to prop shaft or sprocket, is my guess.
Old Apr 23, 2018 | 06:32 AM
Jered651's Avatar
Looks like a spacer for behind the drive sprocket reminds me of the one on warriors. I would check there. You can go to partzilla.com and look at the parts diagram and figure it out.
Old May 4, 2018 | 03:00 AM
85.5-Ytz250n's Avatar
Yamaha_Ripper89
90387-2505V-00
number 25 on the list, goes on output shaft half inside seal half outside. then a plate for bolting sprocket,- flex washer - finally the nut to ensure all is tight in the output shaft... so don’t worry that’s a last step kinda piece and your work so far looks good from what I see of the pics...
Number 25 in the list provided below
Natewally
Jan 7, 2018 09:18 AM
Bubbaz
1) Engine problems..
May 1, 2015 07:29 AM
wickedzr
Jun 9, 2008 03:06 PM
shrek85
Apr 30, 2006 11:22 PM
