PSI in ATV tires
Old Jun 8, 2018 | 09:50 PM
Beartrackeryou's Avatar
Default PSI in ATV tires
I have 22x10-10 ATV tires the max operating pressure is 7psi I currently have them at 4 PSI now I'm not sure if that's too low or too high ??
Old Jun 9, 2018 | 01:47 PM
HawkeyeRider's Avatar
It depends on your preference and the type of riding you do. I keep my rear tires at 4 1/5 psi and 4 in the front. I like the softer ride but still stiff enough the side walls don't fold when taking a fast corner on a trail.
Old Jun 10, 2018 | 01:34 PM
Kymco 450i's Avatar
generally speaking, the harder you ride, the more pressure you need. Racers use bead locks on rims to keep tires on, but if you ride easy then lower pressure makes foe a softer ride. I wouldnt drop below 4 psi
Old Jun 11, 2018 | 11:54 AM
greg74's Avatar
I usually run 5 psi myself. 4 psi is fine but I wouldn't go any lower.
Zuki250
Dec 10, 2005 10:48 AM
Eyetattoo
Oct 3, 2004 10:44 AM
de8212
Apr 26, 2004 10:50 PM
rancor
Feb 26, 2004 12:42 PM
ModdedX
Oct 2, 2001 04:34 PM
