Front differential 400 big bear
I have a 400 big bear all time 4x4. I also have a blown up 350 bruin with a good front diff. But the bruin is push button 4x4 so it disengages. Can i take the 350 front diff and put it in my big bear so its not all tine 4x4???????
Unlikely, if the driveshaft splines are the same, the propshaft spline is the same, the width of the diff, and the length, so the prop shaft isn't either too long or too short, the mounting points on the chassis is the same, it would fit, but what are the chances?
No it won't, for a start, the Big Bear has a front prop shaft with 2 UJs, the Bruin, a short splined shaft with no UJs, so totally different parts, doubtful if the Big Bear shaft would mate up with the Bruin diff nose, but the parts book aint going to tell you.
RubenZ
Apr 25, 2016 09:50 PM
NYH1
Nov 8, 2011 07:51 PM
tehpwnerer19
Dec 11, 2009 03:16 PM
