Need help
Old Oct 3, 2018 | 10:15 AM
Jimmy Murdock's Avatar
Default Need help
Ive got a 1986 Yamaha Moto 4 200 that won’t start. I’ve replaced the starter,carb,coil,spark plug and wire and the valves seem to be set right but still won’t start. Turns over fine. Seems to be getting fuel and good spark that’s what is confusing. Any help would be greatly appreciated.
Old Oct 3, 2018 | 04:42 PM
Kymco 450i's Avatar
Needs compression...run a comp check, if below 75lbs it will never run. If comp is good then look at ignition timing, spark needs to happen at the right time and a good spark is needed. Check spark gap.. should jump a 3/16"gap and be bright blue. If dull orange spark may be weak.
Old Oct 4, 2018 | 08:36 AM
Default Need help
i messed with it yeasterday and got it running now it seems to have a little back fire I guess you would call it or a hick up? When it does this sometimes it dies sometimes it doesn’t. Is there something that needs adjusted? If it makes any sense it doesn’t sound like a backfire from the exhaust more from the front of the engine that’s why I’m not sure it’s a back fire.
Old Oct 4, 2018 | 12:07 PM
Jered651's Avatar
Could be the boot from carb to the head. get it running and spray carb cleaner on the boot all over take your time doing it if the motor changes you have a leak on it. Could clean the carb good and adjust the valves too that might help I have 3 of these machines and they are tough.
Old Oct 4, 2018 | 01:30 PM
Default Need help
i tried the spraying carb cleaner on the boot from carb to head but it showed no change? I changed the carb and it also changed nothing. Thinking now it maybe the valves?
Old Oct 5, 2018 | 10:05 AM
Jered651's Avatar
Check the valve lash yes I have had one where the spark was inconsistent and would do that also and needed a new cdi box. If that is the case buy a oem one off ebay and not a Mr electric after market one.
Old Oct 5, 2018 | 04:30 PM
McBuckNasty's Avatar
Default need help
Hello I need a little help. I have an 80cc Yamaha Raptor. I recently replaced the carburetor do two valves getting bit and all that and now I'm wondering what I could do for lack of power any suggestions
Old Oct 6, 2018 | 06:24 AM
Jered651's Avatar
Might want to start your own post for this one. But did you adjust the valves after you installed them? Air filter clean? Gas clean? inline filter?
Krazzytaker
Jul 24, 2017 04:25 PM
honda400exracer3
Dec 21, 2008 07:17 PM
jrocs
Jul 21, 2004 10:00 PM
Prairiewrench
Apr 29, 2004 01:05 AM
mxer
Jan 26, 2000 10:12 AM
