1998 wolverine
Old Oct 20, 2018 | 09:37 AM
nsburgin's Avatar
Default 1998 wolverine
Its backfiring thru the intake , idles fine,done valve adjustment and installed a new carb . Any one know why it might still be doing this ?
Old Oct 22, 2018 | 03:30 PM
Jered651's Avatar
Could be a rip or hole in the intake boot. Or if its like the warriors there is a parking brake safety switch you bypass by just by fallowing the wires down from the perch. Unplug the 2 wires and plug them into eachother.
Old Oct 23, 2018 | 12:48 PM
nsburgin's Avatar
Thank you but I checked all that . Do you think its a valve ? And the air filter doesnt seal well either . i think it may be that
Old Oct 24, 2018 | 06:28 AM
Jered651's Avatar
yes it could be only takes a hour to adjust them give it a try.
Old Oct 25, 2018 | 01:09 PM
nsburgin's Avatar
Do you now the valve lash setting ?
Old Oct 26, 2018 | 06:48 AM
Jered651's Avatar
Ok I think yours is a 350CC so I looked in my books and for the Warrior and the Big Bear the clearance for valves when machine is cold and at TDC it is .06-.1 mm or(.00236-.00394 in) for the intake. Exhause it is.16-.20 mm or (.00630-.00787 in) I usually stay to the high side of the numbers.
Old Oct 27, 2018 | 06:43 AM
Jered651's Avatar
I have had a warrior that did that too. Idle fine but not rev. I looked in the back of the carb and when I tried reving it up gas spit out the back of the carb. Now this is going to sound corny and like I'm full of **** but the problem was the stator was bad. So there is another thing to check.
Rluppino23
Jun 4, 2023 08:13 AM
Stephen Ayers
Oct 19, 2018 05:45 PM
18Monkmanc
Aug 16, 2018 06:09 PM
jimmyjdc
Aug 2, 2018 09:10 PM
98sport500
Jul 27, 2018 02:23 PM
