Beartracker250
Old Mar 21, 2019 | 08:05 PM
Sport94's Avatar
Default Beartracker250
Have a bear tracker 250, want to know if these are just cold natured beasts, here's why. After start-up, I let run for 5 minutes. When I take off, and give throttle to accelerate to next gear, it just won't take the gas, like its faltering. BUT after about a mile down the trail you couldn' ask for a better performing machine. Good maximum throttle response, plenty of power, runs great. The valves were a little sloppy, set intake on kind of a tight 3 thou, the exh on tight 5. Made no difference, I thought it would. So, are the 1999 bear trackers just that cold natured?
Old Mar 22, 2019 | 04:57 AM
A long time since I worked on one, and the fuel in the carb was bright green from dissolving the jets, as it had stood so long, so I wasn't expecting sparkling performance from the word go. However the symptoms you quote are slightly weak air/fuel mixture, probably due to a partly blocked jet, but Yams are well known for cracked inlet manifolds, which let a little extra air in, so check that too.
Old Mar 22, 2019 | 06:38 AM
Jered651's Avatar
the exhaust valve sounds a little off most yamahas I have dealt with have been 6-8 for the clearance is the number you set it at in a manual?
Old Mar 22, 2019 | 09:06 AM
Sport94's Avatar
Yes, the specs are .002-.004 for intake and .004-.006 for exhaust.
