2001 yamaha warrior 350
Old Nov 6, 2019 | 04:13 PM
Allen Martin's Avatar
Default 2001 yamaha warrior 350
Ok I have a 2001 yamaha warrior has new stator coil cdi battery cam timing chain in perfect time valves adjusted perfect good blue fire will not start spits and sputers some when cranked and soaks my hand when held over carb when cranking question is why won't it start at all I don't care if it runs bad I just want it to start at this point and go from their been working on it for three months driving me crazy please help
Old Nov 7, 2019 | 04:50 AM
First thing is clean the carb out, and check for cracks in the inlet manifold. If it still won't start, check compression. If that is over 90psi, check the piston TDC and flywheel timing mark agree with one another.
Nosliwdlanod
Aug 27, 2018 11:52 AM
knncarter@yahoo.com
May 8, 2014 04:54 PM
Pete7072
Oct 8, 2008 11:04 PM
