1995 Kodiak 400 4x4 front end not pulling
Old Mar 1, 2020 | 01:55 PM
Braunviehjohn's Avatar
Default 1995 Kodiak 400 4x4 front end not pulling
I have 1995 Kodiak 400 4x4 that the front end quit pulling today. When I jacked all 4 tires off the ground and started put in gear all wheels spun. I could grab the front wheels and stop them and the front driveshaft would stop also. Just wondering where I should start looking. Thank you.
Old Mar 2, 2020 | 02:45 AM
I can't remember just how the old 90s front propshaft went into the engine, but if all of the shaft including UJs stopped when you stopped the front wheels, the splines have gone where it goes into the transfer case on the engine. If you are lucky it will be the UJ splines, so new rear yoke and away you go, but if the splines in the transfer box have gone you will need to remove the box and fit a new shaft in the box, if you can still get one, Babbitts don't list a price, so you probably can't.
Old Mar 2, 2020 | 09:05 AM
Thank you I will check that first.
tool_92
Oct 14, 2009 07:23 AM
rjg
Aug 21, 2007 06:24 PM
Redeemed
Jul 24, 2006 09:55 AM
