250 Timberwolf
Old Mar 29, 2020 | 01:41 PM
Brandon Ferguson's Avatar
Default 250 Timberwolf
On this Timberwolf, it will start, idle a little, then die. Is Carb the only thing it could be? Or is there something else that could possibly cause that.
Old Mar 30, 2020 | 02:41 AM
Yes could be ignition, but most likely carb so clean it out and see if that cures the problem.
Old Mar 31, 2020 | 08:38 PM
thall320578's Avatar
It dies without even touching the throttle? Is it idling too low before warming up and just dying? Can you adjust the idle up a little or feather the throttle to keep it lit, or does it still not want to stay running either way?
T.Roberts
Aug 16, 2011 08:59 PM
