1998 Yamaha Warrior 350 will not spark
Old Jun 15, 2020 | 06:41 PM
KRAtv's Avatar
Default 1998 Yamaha Warrior 350 will not spark
The Atv was sparking fine until we had to take off the flywheel. I researched how to put it back on correctly and I think I did. It sparks when I push start it but not with the electric start. Does it have anything to do with the fly wheel? Any ideas.
Old Jun 16, 2020 | 01:58 AM
That problem is common on CDI ignition systems and nobody seems to have an answer. However some recon it is the pick up coil dirty, so I wonder if you have knocked the pick up coil when you put the flywheel back, and altered the air gap between it and the flywheel. On some Yams there is a wire from the neutral switch to CDI, I assume to increase the spark for starting, if this is disconnected it will give those symptoms.
Old Jun 16, 2020 | 07:47 PM
KRAtv's Avatar
I will look into that thanks. Is there a way that you can test the CDI
Old Jun 17, 2020 | 02:22 AM
No, and if it sparks at all it is unlikely to be the CDI.
Dynamodog
Mar 17, 2019 04:07 AM
trekrmom
Dec 15, 2014 10:44 AM
Thowell18
Dec 30, 2012 09:03 PM
