Yamaha warrior 350 problems
Old Sep 25, 2021 | 12:36 PM
Jaystackzz97's Avatar
Default Yamaha warrior 350 problems
Hi i have a 2004 yamaha warrior 350 just did carb clean changed spark plug and did oil change but it is having a problem where when i drive it in high rev its like it goes into neutral for a sec cause i can here the power go wooooom and then i let go of acceleration and it will still be in gear and then if i rev high it does it again like its in neutral so at low rec its not doing it only at high rev and worse on higher gears i have no idea what it can be
Old Sep 26, 2021 | 02:02 AM
I would guess at clutch slip. Try adjusting and if that doesn't work, check clutch plates for wear and glazing.
Old Sep 26, 2021 | 06:29 AM
Thank you will check that out today and keep you updated
Greywolfwarrior
Jul 11, 2020 12:11 AM
Hooly
Mar 6, 2017 04:03 PM
Stud muffin
Aug 25, 2013 08:11 AM
NICKTHOMAS WARRIOR350
Jan 13, 2010 09:07 AM
