Instructions for changing front brake pads on warrior?
How do you change the front pads on a 00 warrior? Not that hard to remove as I removed the 2 allen head screws and the pads almost fell out but it looks like it will be a chore to put new ones in. The rotor guard prevents me from removing the assembly unless I bend it a little and I know there has to be an easier way.Do I have to remove the hubs to make it easier to remove the brake cylinder assembly? Thank You
i have a 2001 warrior i havent had to change mine yet but i know how becasue i grease the rod the tire slips on and my breaks fell out to.you take the brake calliapr off with 2 bolts and the 2 alen screws hold the breaks on so while you slip the allen screws back through make sure the holes on the breaks line up ..its real easy lets me know if this is to confusing to understamd
toonces
Oct 16, 2019 12:11 PM
