08 raptor 250 rear axle bearing
Old Feb 15, 2022 | 10:12 PM
Dark Knight's Avatar
Default 08 raptor 250 rear axle bearing
I have searched youtube high and low and also looked on here and googled it with no luck. I cannot find a good write up on how to replace the rear axle bearings on a raptor 250. Any help would be great, pictures, video, directions ect. I have everything done to where I'm ready to take the axle out but thats as far as I have made it.
Thanks
Old Feb 22, 2022 | 07:37 PM
you guys are a big help....
1. remove the tires
2. remove the brake caliper.
3. loosen the two allen head screws on the right side of the rear brake disk on the collar.
4. remove the right rear hub
5. remove the nut on the axle next to the collar with the two allen head screws in it.
6. Now remove the brake disk.
7. Pull the axle out the left side, if it gets stuck on the way out, put the castle nut back on and use a block of wood and tap it with a hammer.
8. Remove the 4 allen head screws from the rear swing arm at the bearing carrier. once removed you can take out the carrier.
jakesnake222
ATC 3-Wheelers
Jan 13, 2006 05:28 AM
carnivorusraptor
Jun 9, 2004 12:32 AM
RAPTORJOHN
Nov 30, 2001 05:36 PM
kuz28
May 6, 2001 11:04 PM
