03 Warrior 350 Engine Parts?
Old May 8, 2022 | 07:49 PM
Rockeye's Avatar
Default 03 Warrior 350 Engine Parts?
Hello,
I was able to get a really good deal on a Warrior that wouldn't start. Well the reason that It won't start is because the exhaust valve snapped off and went through the piston. Im currently on the hunt for parts to replace basically the entire top end. Warrior 350 cylinders are apparently hard to find or Im not looking in the right places. Where should I be looking for everything? Are there favorite brands/companies that everyone uses?
Thanks!
Old May 9, 2022 | 03:02 AM
How badly has it scored the cylinder? If a rebore would take the marks out, get it bored and oversize piston. If head is beyond use, 350 Wolverene head (circa 2000) is same part number, 350 Big Bears and Bruin heads have different part numbers, but may be close.
Old May 9, 2022 | 03:30 PM
Rockeye's Avatar
The whole jug was trashed. The valve that was dancing around in the CC really did a number on all the surfaces.
I found the parts around the internet. They should be here in about a week or so.
Below you can see the pistons face.
RandyF
Apr 12, 2013 07:52 PM
ronnieb8406
Dec 29, 2008 07:24 PM
s3swamp
Sep 25, 2008 03:11 PM
87warrior350
Aug 20, 2004 01:52 PM
