Yamaha warrior 350 not starting!!
Old Jun 11, 2022 | 02:33 PM
TVell00's Avatar
Default Yamaha warrior 350 not starting!!
So I recently blew my motor up on my 1998 Yamaha warrior, I then fully rebuilt a top and bottom end off of my other 2002 warrior and threw that on there. Now I have spark, good compression ( put my finger over the hole and it blew it off ) and good fuel. And the battery is charged so I have no clue what the problem is. It will start for half a second and continue to spin.
Old Jun 12, 2022 | 02:01 AM
Double check that the timing is right, both TDC by the flywheel actually is TDC by the piston, and that the cam timing agrees with the TDC mark. If they are OK, change the plug and try again. If it still won't start, clean the carb out, or just swap to the spare carb and see if that fixes it.
Greywolfwarrior
Jul 11, 2020 12:11 AM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
rynearson92
May 9, 2010 03:23 PM
Coyotechaser
Jun 20, 2004 09:15 PM
