wolverine snorkel
Old May 3, 2001 | 08:21 AM
Camo-man's Avatar
Looking for info on how to snorkel a wolverine.
type of material needed, and a some direction on
how to layout snorkel. DO I tie in the breathers for the front and rear end to the airbix????
On my carb the breather line has a device that does not let material back in should I reroute this?? Any info would be greatfull,,,
thanks....
Old May 3, 2001 | 08:51 AM
mray's Avatar
don't know about the snorkel but was wondering how you like the modified clutch? can you tell a big difference?
Old May 3, 2001 | 09:14 AM
Camo-man's Avatar
Yes,It is a noticable improvement, It helped out alot with the big tires......quick response
no extra cost , just elbow grease......
Old May 3, 2001 | 10:58 AM
mray's Avatar
where do I find out exactly how to modify the clutch?
Old May 3, 2001 | 11:08 AM
Camo-man's Avatar
There have been a few posts in this forum on how to do it. Search in Modification section, I think
I drilled a 3/16 hole about a 1/4 inch from the
end of each clutch shoe, this lightens up the clutch shoes so they enguage quicker. Better look for the post to make sure I'm right...
Old Feb 19, 2004 | 11:06 AM
wickedwolf's Avatar
Default wolverine snorkel
Hey Camo-Man I recently snorkeled mine. Used wet vac hose and ran it up to the front fender then put an elbow on top. Only problem I'm havin now is that I believe my HMF exhaust is creating not enough back pressure and it stalls when I get down deep in the water. I'll try and get pics on here. Just make sure you keep it off the exhaust.
Customer Service #1
May 15, 2020 08:46 AM
Steeldon
Sep 9, 2015 09:38 AM
switzomatic
Aug 24, 2015 12:57 PM
Ean
Aug 20, 2015 07:13 AM
Cantbuytime
Aug 17, 2015 06:33 PM
