Timberwolf Timing Marks Not Lining Up
Old Dec 11, 2022 | 07:44 PM
Blueoval78's Avatar
Default Timberwolf Timing Marks Not Lining Up
Hello everyone, I am nearing the finish line in my '94 Timberwolf 4x4 crankcase swap / top end rebuild. Today I was trying to set the cam sprocket in the proper position for the valve timing but ran into a hiccup. When I line up the TDC line on the crankshaft, I can't get the camshaft sprocket TDC mark to line up perfectly with the reference line on the cylinder head. Basically I am off by half a tooth, meaning if I move the chain over one tooth, I am now not lined up but on the other side of the reference line. This is of course after I've installed the tensioner and rotated the engine 1/4 turn in either direction to make sure the chain is properly meshed with the lower crankshaft sprocket. Is it ok to run the engine like this? Does it matter which side of the TDC mark I am on for the cylinder head if I can't get a perfect alignment and have to choose either before or after the mark?
Old Dec 12, 2022 | 03:28 AM
Often happens. I always put it so that as the chain stretches, the mark will get closer to correct, rather than further away which, I think, is how you have it in the picture.
Old Dec 12, 2022 | 07:51 AM
Blueoval78's Avatar
Great, thanks!
gottooride
Mar 30, 2020 06:02 PM
Let It Rip
Oct 26, 2016 02:36 AM
Polarisman1123
Feb 28, 2015 09:55 AM
armyguy7776
Oct 29, 2008 06:40 PM
odysseyjunk
ATC 3-Wheelers
Feb 18, 2004 10:19 PM
