View Poll Results: Help me
Transmission
0%
Cluch
0%
Rear-end
0%
Transfer case
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
Please help
Old Jan 30, 2023 | 07:45 PM
Anthoney hughes's Avatar
Default Please help
My 1989 yamaha moto 4 250 is not shifting gears and not moving when trying to ride it had low to no oil when it happened I dont know what is wrong with it someone please help me.
UPDATE: the high low reverse lever is not working either i will try and mess with it this weekend
Last edited by Anthoney hughes; Feb 7, 2023 at 10:03 PM. Reason: Tried the high low gear
Old Jan 31, 2023 | 02:50 AM
If you can't get the gear lever to move enough to change gear, it is a gearchange mechanism fault, if it does seem to change gear but doesn't drive, most likely is a clutch gone. If you want to check the rear axle etc, try to feel the universal joint through the rubber boot between transfer case and swinging arm. If you can feel it, engine off, bike in gear, shove the bike forwards while feeling that UJ, if the bike will move, and the UJ is going round the rear end is OK. If it won't shove, try shoving it backwards. Not quite as certain, but if the UJ is going round the rear axle is probably OK.
Clutches, you could try adjusting the multiplate clutch, but if it is bad enough not to drive at all, it probably won't have enough adjustment left and/or the plates would be glazed. So, if adjustment doesn't work, remove the clutch cover and dismantle and inspect both clutches. Centrifugal clutches usually work OK until the shoes wear down to their steel backing, easily seen. Multiplates need each plate measuring for thickness and springs checked for length. Get the workshop manual, it tells you how to adjust the clutch and what thickness, etc, plates need to be.
Old Feb 1, 2023 | 01:16 PM
nny's Avatar
nny
Hi so these quads have a hi low reverse shift lever. If thats not in gear then it can act like its not shifting. I know its a simple question but could you check and let us know. It will help properly diagnose.
buckbogren
Jun 15, 2011 01:02 PM
joechum
Apr 8, 2007 12:13 PM
