Raptor Oil
The Owner's Manual says to use 10W30 oil for temperatures from 0 - 25(I think) degrees C, and 5W30 for temperatures below 0 C. Wouldn't 5W30 work for the whole range? They're both 30 weight oil at higher temperatures...aren't they? My cars use 5W30 all year round. Also, I don't plan on riding when the temps rise above 25C. I want to use the 5W30 all year round. I do minimal riding below 0C so I really don't want to have to change the 10W30 to 5W30 in the winter when I'll only be using the quad a bit when there isn't enough snow for the snowmobile.
Depends on how hard you ride. If agressive I would go with a high weight like 20w. If you ride it like a puss the use 5w. Quad engines are not car engines so you cant compare the two. After 50 or so hours I would strongly recommending synthetic oil.
"ENDO"
"ENDO"
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
