HELP BALSTER TIRES
Old May 7, 2001 | 09:52 PM
blasterboy104's Avatar
okay im getting razor tires for my blaster im to cheep to buy new rims what size tires do i need thanks
Old May 8, 2001 | 10:26 AM
TurfBlaster's Avatar
Read the numbers on the side of the tire that is on there. I can't remember what stock is, like (21 x 10 x 8) or something like that. The most important number to keep the same is the last number, it is your rim diameter. The other two are tire width and height.
Old May 11, 2001 | 08:11 PM
Emblazer's Avatar
Nono, the first number is the diameter, the second is the height and the 3rd is the width. Make sure that the first # does not change. Getting a 10 in the rear will make you more stable because it is wider.
Old May 11, 2001 | 11:04 PM
jacob14's Avatar
wait a sec, the guy that posted before mine is wrong, it is height, width, then rim size, how could the rim be taller and wider then the tire, get 20 11 8 for the blaster, i got that and i really like it
Old May 11, 2001 | 11:52 PM
Daredevil1's Avatar
I got the 18x10-8 Maxxis Razr MX's and I love them, they have no sidewall flex that i can notice, they hook up great, slide great, and the lower gearing gives me really fast acceleration. Great tire, good choice on the razr's, and the last number is the rim size. When getting tires for the blaster on stock rims, make sure that they arent too wide or they will rub on the half floorboards when they flex in a slide. Aftermarket rims will eliminate this but just check first to make sure they dont rub a lot and get the rims later.
Old May 16, 2001 | 09:27 PM
ProCrctBlaster's Avatar
ive got a blaster to and im going to razrs if youve already got them tell me how they are.MODS pro circuit platinum and 304 silencer,v force reed valve.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
