1988 Warrior RUNS HOT!?!?!?!
Old May 21, 2001 | 12:59 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Exaust pipe get cherry red after a feew minutes of running time and backfires out carb and exhaust.
I have changed or checked the following:
- changed exhaust pipe donut
- changed intake o-ring on carb side
- changed intake o-ring on cylinder side
- changed fuel diaphram in carb
- checked valve gap
- checked spark plug and gap
Please send information if you have any suggestions. This problem is costing me riding time!
Old May 21, 2001 | 04:41 PM
FourStrokeFan's Avatar
Sounds like you're running lean. Have you tried increasing your main jet size?
Old May 21, 2001 | 08:10 PM
yamahagye's Avatar
if your valves are adjusted too tight it will run hot. this happened on my XR250
Old May 23, 2001 | 01:34 PM
weedy's Avatar
I have checked the valves and they are adjusted right. This thing must be sucking in air from somewhere making the thing extreemly lean. I am close to wits end with this thing. It sat up for about a year?
njrider64
Jul 4, 2017 01:40 AM
big_g_squared
Jun 28, 2015 04:17 PM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
dunc_n
Aug 26, 1999 09:32 PM
