need info on how to install 12t on raptor!!!!
Old May 23, 2001 | 06:49 PM
YAMAN's Avatar
I TRY TO INSTAL MY 12T SPOCKET ON MY RAPTOR BUT HAVING PROBLEM LOOSING THAT BIG HOLDING NUT.TO LOOSE THAT NUT DO I HAVE TO TURN CLOCKWISE OR ANTICLOCKWISE.ANY TRICK WOULD BE GLADY WELCOME.THANKS!!!!!"""""""""""""""""""""YAMAN
Old May 23, 2001 | 08:09 PM
Xplor's Avatar
YAMAN...did you get the 12 tooth sprocket here in Quebec or did you order from the States? I am planning on ordering a couple sprockets real soon.
Thanks
Old May 23, 2001 | 08:41 PM
Raptorrider2001's Avatar
Counterclockwise, just like a regular nut. You will need a 32mm socket. I think that is equal to a 1 1/4" SAE. Loosen the chain adjustments on the swing axle to get some slack and then readjust it when you have the 12 on.
Old May 23, 2001 | 10:06 PM
Mr45auto's Avatar
Exactly as above but if you remove the left footpeg you'll have a far easier time. It's only 4 bolts total and easy. Keep the foot brake on and use a long breaker bar and the nut will come loose easily. I assume you bent the locking tabs flat.
Old May 23, 2001 | 10:22 PM
YAMAN's Avatar
THANKS ,I JUST NEED TO FIND A 32 MM SOCKET AND THAT SHOULD BE NO PROBLEM.
I ORDER MY SPROCKET FROM THE SPROCKETSPECIALIST.COM DIRECT ON THE NET .THEY HAVE STOCK AND SHIP IT BY MAIL ,IT TAKE ABOUT 2WEEKS TO GET IT COST 32.00 CDN + 11.50 DUTY.
Kaleb_00
Jun 1, 2016 09:15 AM
Aug 21, 2015 01:23 PM
HYS
Aug 18, 2015 12:28 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
