Lonestar or DuraBlue?????
Old Jun 6, 2001 | 05:21 PM
fourlix's Avatar
My Durablue Eliminator,$289 came in a box marked Banshee, Blaster, Raptor With the stock axle out on the ground next to the Eliminator you can obviously see that it is offset differently than the stock axle. By using the shims that came with it, you can offset one side more than the other to even it out on the Raptor.
..........But that is kinda cheesey if you ask me.
Get the Lonestar for the RAPTOR ! 'cause you can wind up with a lonestar banshee axle if you aren't careful.[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jun 6, 2001 | 07:18 PM
NotuRaptor's Avatar
Bash,
Can you post the correct part number for the Lonestar axle?
Thanks
Old Jun 6, 2001 | 08:32 PM
yamahagye's Avatar
don't get the lonestar or durablue! get the RAD designed titanium axle. it is bullet proof and adjusts to 2inches wider than stock. it is only $700.00. don't cheap out, get something that will last.
Old Jun 7, 2001 | 03:10 PM
FourStrokeFan's Avatar
NotuRaptor,
I called LSR and they said the Banshee axle is LS-Y1 and the Raptor is LS-Y3 and LS-Y4. I should have asked if the Y3 and Y4 were different lengths.
Bash,
Thanks for the measurements. It sounds like yours is definitely centered. Maybe my measurements were a little off, since my numbers were close to that.
letitsnow
Jan 1, 2001 05:55 PM
scotch54
Oct 25, 2000 02:23 PM
BUBBAG
Sep 27, 2000 02:31 PM
collegefunded250
Mar 21, 2000 05:18 PM
250rCanCan
Aug 17, 1999 11:58 PM
