thinner base gaskets? (banshee)
Old Jun 7, 2001 | 08:44 PM
H300F's Avatar
what would thinner cylinder base gaskets on a banshee do exactely to the performance? it says they change the port timing or something like that. they are available from veto's racing. they have 2 sizes available.
what would this change as far as performance?
Old Jun 7, 2001 | 10:39 PM
brokemybanshee's Avatar
It might change the port timing a little, but I wouldnt imagine very much, they are used to increase compression for running higher octane gas or race gas, I hear they are hard to get a good seal? But dont know for fact.
Old Jun 8, 2001 | 12:24 PM
H300F's Avatar
so if i put them on i will definately have to go with race fuel?
what do they add as far as performance and how will the change the way the power comes?
Old Jun 8, 2001 | 03:08 PM
chicneater's Avatar
I wouldn't run a thinner base gasket, you will take to big of chance of it not sealing, then you could end up with a low RPM or idling performance, or if you holding a long rev, like say at the dunes, you can actually "suck" the gasket and burn down the cylinder(s).
EIF
Apr 20, 2017 07:15 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
tysonbully
Sep 28, 2015 02:30 AM
