GRIZZLY MAINTENANCE
Old Jun 15, 2001 | 08:19 PM
NorthernEdge's Avatar
WHEN DOING REGULAR MAINTENANCE ON MY GRIZZLY(2000)WHAT EXACTLY SHOULD I DO?
OBVIOUSLY CHANGE THE OIL AND MAKE SURE IT HAS A CLEAN AIR FILTER, BUT HOW MANY GREASE FITTINGS DOES IT HAVE AND WERE ARE THEY? IS THERE ANYTHING ELSE?
Old Jun 15, 2001 | 09:11 PM
grizzlytim's Avatar
There are two drain plugs, one has a screen that will need to be cleaned. The front drive shaft u-joints have grease fittings, you can get at them from the bottom. Remove the rear break drum and clean the breaks and seal. Check and clean the front breaks. Check and tighten bolts. Tim [img]i/expressions/face-icon-small-happy.gif[/img]
dannytas
Sep 26, 2017 06:31 PM
Pgbama11
Jan 16, 2016 08:19 AM
cboler9
Sep 24, 2015 08:35 PM
caveeagle
Sep 19, 2015 01:20 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
