How to put a banshee on a diet??
Old Jun 22, 2001 | 02:59 PM
Shananigan's Avatar
What are some of the biggest bang for your buck items that you can change on a banshee to lighten it up. Was wondering what kind of weight differance there was in stock and aftermarket swingarms and things like that.
Old Jun 22, 2001 | 03:18 PM
Backcountry's Avatar
--Ditch the parking brake mess...get a new clutch perch too when you're done...
--Dump the "safety" net BS on the footpegs
--Cut the front fenders.
--Toss the TORS.
--No air-box or radiator overflow rez.
--Some of the aftermarket suspension components are lighter. They use stronger materials which allows for thinner material for a given strength. Saves wgt that way.
--Say bye-bye to the front bumper.
--Drink lite beer and fill the frame with helium [img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 25, 2001 | 07:31 PM
409LongRod's Avatar
If your drag racing, loose the front brakes, you can cut all the extra fender brakets off, which may not lighten it to much but cleans up the frame qutie a bit. A chromemoly arm will way about half of what a comparable steel one will. You will probably save 8-10 lbs with that. Chromemoly a-arms, c-moly subframe, or if you got the coin, get a complete c-moly frame!!
Old Jun 25, 2001 | 11:02 PM
H300F's Avatar
what is a sub frame? i thought it was by the rear end grab bar? do you have to cut that out and weld a new one in? how much are they?
Old Jun 27, 2001 | 01:31 PM
409LongRod's Avatar
If you look at the frame above the foot pegs, you will see where the lighter section of tubing goes back to support the back of the seat and the fenders. I don't know if lonestar sells just a sub, but some guys i know cut thiers off and build a new one out of moly and weld it on...
Kaleb_00
Jun 1, 2016 09:15 AM
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
