Blaster Gearing
Old Jun 24, 2001 | 10:04 PM
m98sniper's Avatar
Im currently running my blaster with a 14t front sprocket and a 44t rear. Im looking to go to either a 40 or 41 tooth rear for more top end. The blaster has no mods and I'm wondering if it will have problems turning a 14-40 combination in top gear, or if it will have some power to spare? I do use it for some deep bush riding and like a powerful first gear, wondering which would be best for me, and how much of a top end difference there would be between a 40 and 41 tooth? current top speed is 35mph and I run 22*11 dirt dogs
thanks
Old Jun 24, 2001 | 10:45 PM
dirt817's Avatar
If your blaster only goes 35mph I wouldn't worry about gearing. A stock blaster would have enough power to turn that combo on flat ground, but if you ride in deep brush you might wont to invest in a reed spacer, air box vents, and a reed spacer. I chose to mention these products because they are cheap, easy to install, and would add the power you need.
Old Jun 24, 2001 | 11:20 PM
TitanRacing25's Avatar
35mph?????????? good god!! can you keep the front end down in the top gear???????
Old Jun 30, 2001 | 02:10 AM
jts's Avatar
jts
a blaster is not made for "deep bush riding". 35mph is sad, but I believe it . You need a 4x4.
Old Jun 30, 2001 | 02:16 AM
Blaster96's Avatar
The blaster can do anything. Only 35 mph. That is insane. My blaster can reach about 60....
John Reed
Sep 9, 2015 03:46 AM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
