Wolverine Wheelies
I can ride a wheelie just by hitting the gas, leaning back and pulling up hard. ( I think it is because I have my idle set a touch high) Then again I must either be strong or put alot of weight on the back end.
All of you guys that lift the shifter rev it up and drop it into gear, have any of you ever had clutch or tranny problems? Do you guys think that can do significant damage?
#15
even when a quad is auto clutch, it still has a clutch with the tranny, you just dont control it. i did wheelies that way on my recon, untill i could do em sitting down in first with out any tranny help, now my new trick is doing them in high gears with my feet on the racks.,... scary!
#17
I cant wheelie my wolverine unless I am on a bit of an incline like they talked about before or I stand on the wheelie bar/rack depending on wether i have the rack on or off. I have a decent ammount of power but i noticed a bit of a torque dropoff at the bottom but the cam really gives it mid power and thats what i use the most.
#18
