raptor misses
Old Jul 2, 2001 | 01:14 AM
raptor630's Avatar
The bike runs fine at wide open throttle but has a slight miss at constant throttle at about half open. This gets worse when in nuetral and I hold the gas open a little. Its not bad enough to be a real problem just a little aggravating. I know it isnt the dynojet kit becuase it ran fine after it was installed for about two months. Could a clogged jet cause this?
Old Jul 2, 2001 | 12:32 PM
mtecate4g's Avatar
after your bike breaks in you have to readjust the float level or it will run a little funny. Also you may need to adjust your valves. The only other thing i can think of is try changing the spark plug.
Old Jul 2, 2001 | 01:40 PM
raptor630's Avatar
Thanks for the info. I had the dealer adjust the valves after the first 30 hours. I had to replace the plug once so I will check the gap on it. I don't really think that it would be the float level though because it runs fine when accelerating or riding normally so I don't think its starving for fuel. It only misses when at a constant rpm.
Old Jul 4, 2001 | 01:43 PM
RapTech's Avatar
With the jet kit and probably modified airbox/filter, I'm not sure what to advice but to me it sounds like its too lean at mid range. Try turning out the mixture screws a little (up to 1 turn out). You may need to raise the jet needles a bit to richen mid range.
When its hesitating, what happens if you apply the choke a little?
bmxatv10
Oct 14, 2022 06:23 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
