Reverse Rev Limiter
Old Jul 16, 2001 | 10:39 PM
400K's Avatar
I have solved the Kodiak rev limiter in rev problem. First remove the seat, then the air box. Standing on the oil filter side about 4 inches to the rear there are the tranmission sensors. The first sensors is neutral, then park, finally reverse. I used a DVOM meter to find it buy selecting differnt postion on the gear shifter. Removed the sensor then moved the shifter back and forth to see how it works. There is 12.5V in Rev position only, when the transmission is put in rev a plunger comes out of then end of the sensor causing a open circuit and the rev limiter to come on. It is a very simple fix, all that has to be done is run a wire from the sensor to ground. If the wire is removed the rev limiter/light is on all the time. What I did was run a wire from the screw head of the sensor to a toggle switch then to ground. Then it is just like a Polaris, you just make a over ride switch. This does work, you can try this but just taking a wire from the sensor to ground, then jack up the rear of the quad and see for yourself. 400K
Old Jul 17, 2001 | 12:18 AM
400K's Avatar
I thank you would be nice instead of a bunch of views[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jul 20, 2001 | 06:32 PM
mudrabbit's Avatar
Thanks, I have not had a problem with the reverse limiter kicking in, but see a lot of posts where others do not like it. If you do not mind I will pass along your info. Thanks again from down on the bayou.
Old Oct 12, 2003 | 10:22 PM
vampirerider's Avatar
Default Reverse Rev Limiter
400k, I just realized today that my Y2K Kodi has the reverse rev limiter. That wont do at the Highlifter Mud Nationals )) Did a search and found your fix. Thanks alot for the research and post. Your dilligence way back then has made my life much easier today. 3 cheers to you. I also found another post when I did my search where a guy needed the same info. I let him know where to find it. So you have helped two more. I just love this place.
Old Oct 14, 2003 | 10:31 PM
TheIntimidator's Avatar
thank you, finnaly the power i need to back out of those mud holes that are getting tooo deep...
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
