HELP my Warrior has starting problems !!!!!!!!!
Another reason that you should add a pull rope lke on the 87 and 88's. It could be the starter clutch. I had the same problem but backwards. it would not dis engauge. If the starter is spining it might also be the gear that attaches the starter to the flywheel.
