Problem with back End of Warrior????????
Old Aug 29, 2001 | 10:21 AM
Atvsport400ex's Avatar
I have a 2001 Warrior and it is about 6 months old and the other day i was messing with the rotor and i noticed it was a little loose but it is loose at the axle so i tried to tighten up the big axle nut but i couldn't buge it so i dont no weither i should leave it alone like it is or what should i do the bike is still under warrenty so if anyone has any info on what to do let me know.......
2001 Blue Warrior
AC Front Bumper
DG nerfs
Rear Holeshots
150 Main jet
FmF megamax II pipe
Renthal Bars with red scott grips
K&N
Old Aug 29, 2001 | 11:00 AM
2001atv's Avatar
My Warrior and Blaster and my brothers Blaster are all like that. If you grab hold of the rotor it will wiggle just a little. I have always just figgured thats the way it is. It has not lead to any problems and the brakes work great.
Old Aug 29, 2001 | 08:14 PM
Tooey's Avatar
I would take it back and get it checked out...
Old Aug 29, 2001 | 08:17 PM
Mr45auto's Avatar
Mine did it since new, no troubles out of it.
Old Aug 29, 2001 | 11:09 PM
ridnwarrior's Avatar
Could this be full floating rear brakes! I don't think so.
Old Aug 30, 2001 | 12:08 AM
WyoDuner's Avatar
This seems to be a pretty common Yamaha thing from what I've seen. You need to tighten the big axle nuts. Also, while you're at it make sure the 22 mm nuts holding your hubs on are tight. All 3 Yamahas that I bought new needed all of these tightened a little while after I bought them. I would think that you would cause wear on your splines if they are not tight.
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
generalpops
Jun 5, 2015 08:23 PM
generalpops
Jun 3, 2015 08:25 PM
