Problem with Banshee please help
Old Oct 28, 1999 | 12:03 AM
Rocky's Avatar
the manual you are referring to is talking about pressure testing not a compression test they are different a compression test checks the condition of the cylinder pressure testing is what you do to the entire motor to check if you have any air leaks, usually done after a complete rebuild
Old Oct 28, 1999 | 06:37 PM
Dune-it's Avatar
Thanks Rocky, it was confusing to me. VENOMOUS, are you doing the compression test with a gauge connected to the spark plug hole? Or are you doing a leak-down test? Rocky's absolutely correct, two completely different animals!
Old Oct 28, 1999 | 11:13 PM
VENOMOUS's Avatar
I was doing a compression test of the top end. The book states in chapter 3 not sure which page but towards the end, that Yamaha made no specifications of what optimal compression should be. It just says that each cylinder should be within 10% of each other. I didn't do a 2-stroke lower end pressure test yet and I'm probably not going to since I found my problem with the bent valve needle. The repair manual was the Clymer brand and it's not much good unless your a real shady shade tree mechanic. If I didn't know as much as I do about working on motors and such I sure wouldn't rely on that thing to help me. In the book it even has a little picture of a cheap little compression tester in the plug hole if anyone wants to look and see that there is no recomended compression for the Banshee by that book.
Jeremiah Lucas
1989 Yamaha Banshee
Cole Hadden
Jun 15, 2025 09:05 AM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
