How can you make Banshee and Honda250R rims interchangable?
You can have two bolt patterns on the same wheel. Just rotate the patterns 45 dgreess from each other. You can add a new pattern to a wheel by removing the studs from a hub with the desired pattern and lay it in the wheel. Take care to center it and rotate the spacing. Mark the center of the holes and drill to your stud size. Wha-La one set of wheels for two bikes.
Ben
Ben
Jul 7, 2015 11:00 PM
