Wolverine Headlights
Old Nov 20, 1999 | 10:03 PM
boomer's Avatar
I dont see any difference between the high and low beams on my headlights. Is that common? Also, anyone running Mobil 1 in their Wolverine? If so, how do you like it?
Boomer '99 Wolverine
Old Nov 20, 1999 | 10:47 PM
mxer's Avatar
high bean is goes futher out then low
Old Nov 21, 1999 | 08:11 PM
thumper4x4's Avatar
The high beams are just that, they shine higher, thus farther.
I have run Mobil 1 and Syntech, 5w-50.
Liked them both.
http://www.geocities.com/norcalatv
Old Nov 22, 1999 | 04:33 AM
HERBERT C.'s Avatar
boomer, I too didn't see much of a difference between low and high beam. I got tired of replacing the bulbs, seem to go through alot of them on my wolv so I replaced them with a pair of HELLA 500's. Wow what a big difference. I had to fabricate different mounting brakets and moved them foward 2 1/2 inches.
Herbert~~99Wolverine & 89LT520
Old Nov 22, 1999 | 02:20 PM
Harold's Avatar
I agrree with you Bommer, you can't tell alot of differance between low and high beam, low beam just disperses the beam a little wider. Since I ride in water and mud alot I've never been able to seal the lights to keep the moisture out, I really don't like these lights, I even run light covers on them which helps to keep them clean there a real pain in the butt to clean!! I plan on replacing them soon. I added a Hella light on the front rack where the speedometer mounts, whow what a differance it makes!!!
Harold Wells Raleigh NC 98 Wolverine& 97 Timberwolf Blueribbon Coalition Member
Whitelx1
Oct 2, 2015 10:55 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
PrairieDog126
Sep 16, 2015 01:33 PM
