Banshee tranny oil
I recently bought a 97 Banshee, I need to buy a manual, but haven't yet so I have a few questions for the banshee owners.
1)what tranny oil do you use? weight?
2)how often do you change the oil?
3)I believe the tranny holds some over
1.6 quarts.. Is this correct?
4) whats the best time to check this level? hot cold? can you add too much oil?
5)do you screw in the dip stick or not to check the level?
I changed the oil and it seems to want more than the required amount to bring it up the desired level.
Thanks
Dale
Thanks
Dale
If you would read the little book that comes with it you would know. I guess that little book does not come with a piece of crap banshee like yours.
Any way, any good 20w 50(Irun Castrol) oil will work just fine. Check the oil when it is warm. Put the dip stick in the side case, do not screw it in. Put about 1.6 quarts of oil in it. Them you should be all set for the race on Sunday.
96 Banshee and 96 Warrior
1.6 Qts. sounds like a little too much to me, I could be wrong though.
I have a friend that races pro. He told me one day he runs Dexron ATF in his Banshee, and his race Banshee with a Tri-Z motor in it (250cc max). I tried it in the wifes Blaster and it works great. I just change it every 4 rides and no probs, and it seems to shift a little better. The Blaster takes .75 Qts. I kinda dought the Banshee takes twice that much.
Hope this helps
Hope this helps
Logan Collins
Sep 5, 2015 08:03 PM
Jul 7, 2015 11:00 PM
