Raptor Header Pipe
Old Oct 22, 2001 | 06:44 PM
rapTOr24's Avatar
What header pipe can I go with if I have a GYT-R exhaust- I don't want to have to modify the exhaust or the Header pipe so what one will bolt right up?
Old Oct 23, 2001 | 12:30 PM
raptor720's Avatar
Rap,
DONT WASTE YOUR MONEY ON A NEW HEADPIPE!!!
From your build list, it is clear that you do not have a big piston or cam. In such a case, you do not need a full exhaust. Currently, your setup, if properly jetted, will provide as much if not more torque than any aftermarket full exhaust. Granted, some of the aftermarket systems will develop 1-3 additional hp at top rpm BUT how often are you running wide open??
Old Oct 23, 2001 | 01:19 PM
vraptor's Avatar
raptor720 is right the GYT-R and stock headpipe are fine for the stock 660 motor. I run a big gun headpipe but the plan all along was bore it out and run high comp piston/cam (being done today). I started with the big gun silencer and a month later added the headpipe---> no appreciable difference in performance. The flow characteristics of the stock pipe are more than adequate for your specs, save your money
bmxatv10
Oct 14, 2022 06:23 PM
mrtidy
Feb 3, 2016 05:00 PM
black_thunder
Sep 22, 2015 07:59 PM
greg86hd
Sep 16, 2015 12:32 AM
Bigtwin700
Sep 9, 2015 09:32 AM
