wolv carb
Old Jan 4, 2000 | 06:07 PM
wolv99's Avatar
My wolverine has recenly been leaking a
little gas from the carb.its mostly where the carb meets the air box.anyone know?
99' Wolverine, FMF MegaMax2 Pipe, K&N jet kit and filter, OxLite brush guards,Skidplate, DuraBlue Elimanator axle and lift kit
Old Jan 4, 2000 | 06:34 PM
feara400's Avatar
Have you checked to see if your fuel valve needle was sticking open? This would be the first place I would check. You can drain the carb bowl and get rid of any dirt that may have found its way in to your bowl by opening your bowl drain tube. There is a screw at the very bottom of your carb (there should be a hose very close to it). Turn this counter-clockwise to open it for a few seconds to flush out the bottom of your carb. Gas will flow from the near-by tube. Close the screw (turning clockwise) to stop the flow. DO NOT CLOSE THIS SCREW TO TIGHT!!! This will damage the seat and it will leak. If this doesn't work, you will probably have to remove and clean the fuel valve (connected to the float) and the seat. But try draining the carb first. Also you should have a fuel filter on you machine. I had one on my '00 Wolv and did not have problem one with the carb. BTW, watch out for bent rear axles on the Wolv's.
a Fast Boy From Illinois (FBI) Riding a 2000 Honda 400EX
Old Jan 5, 2000 | 05:18 PM
wolv99's Avatar
hey man if any on know bent axles its me. went through 4 until i got the eliminater
Old Jan 5, 2000 | 05:19 PM
wolv99's Avatar
oops forgot to say thanks! ill try that
Old Jan 7, 2000 | 08:45 PM
feara400's Avatar
There is a machine shop in IL that will straighten your axles for $15. Maybe try to find one in your neck of the woods.
a Fast Boy from Illinois -(FBI)- Riding a 2000 Honda 400EX
Old Jan 15, 2000 | 12:51 AM
derekjes's Avatar
I'd be very hesitant about straightening a bent axle... especially more than once. Once an axle bends, metal fatigue starts. Once you straighten that axle, the metal fatigue is increased, and it will bend much easier next time. Each time you bend and straighten it, the axle will become weaker and weaker. Take a piece of metal wire, for example... Keep bending it back and forth, and eventually it will break. It's the same idea with an axle. Then you also have to take into consideration, the fact that a machinist would have to heat the axle a lot in order to straighten it, which would take the hardness out of the steel, and make it even easier to bend the next time. You might get away with straightening an axle once, but if it bends again, your money would be better spent investing in a new axle.
[This message has been edited by derekjes (edited 01-14-2000).]
Old Jan 17, 2000 | 12:58 PM
goblin's Avatar
check and make sure the inlet for the filter box hasnt worn a hole through the top of your carb. they have been known for this
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
