tires
Old Jan 5, 2000 | 10:57 PM
blstrpro's Avatar
I have a yamaha blaster and I was wondering what size tires I should get for the rear? I'm thinking about 20-11-8 becouse I only ride on trails in the woods and some mud. I think the 18-9.5-8 look better but I also think it makes it set to close to the ground for trails with alot of rocks.If I get the 18-9.5-8 I would change the front sprocket to make up for the lost speed. Whitch one?
Old Jan 6, 2000 | 01:01 AM
dstevenson's Avatar
I have several blasters with stock tires, but this year I started running with 18" turf tamers. I like the tire ok but even with a 14 tooth sprocket (1 tooth increase) in the front I loose 1-2 gears. If I were going to replace them I would get 20". I think the lowered back end is not too bad, you just have to avoid more rocks than you're used to. But I don't recommend 18".
Old Jan 6, 2000 | 01:11 AM
Kiwi-Craig's Avatar
Check out the guys at blaster central, they have published several tyre tests and comparisons for Blasters, http://www.geocities.com/Baja/Canyon/2536/
Craig
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
