raptor float bowl vent hose with jet kit
Old Oct 25, 2001 | 04:47 AM
EDD's Avatar
EDD
im not having any problums with my raptor i was just reading over my jet kit instructions and say that it says to remove the float bowl vent tubes,has anyone done this?mine has run fine for 4 months with them on but should i remove them?thanks for youre in put
Old Oct 26, 2001 | 02:34 AM
yambike's Avatar
EDD,
Could you scan or retype the directions about removing the vent hoses? I have a Dynojet kit and it doesn't say anything about that. I'm wondering if I may have an earlier version. Anyway, the reason I think they may say that is to remedy a bogging problem when riding over whoops or landing hard from jumps.
Old Oct 26, 2001 | 03:55 AM
raptor720's Avatar
Don't remove the tubes. They are not causing you any troubles.
ON the bog issue under the circumstances you mentioned, it is the cv slides dropping from the sudden impact. Mikuni told Yamaha about this problem.
Old Oct 26, 2001 | 09:05 AM
EDD's Avatar
EDD
ok i went and dug out the directions .i was looking at the trouble shooting guide not the install sheet.its mentioned repedietly in the trouble shooting guide but it must not apply to the raptor.thanks for youre guys input i should have looked closer.
Old Sep 1, 2002 | 04:10 PM
ANUFSED's Avatar
I noticed this as well in my DynoJet instructions. Has anyone called them to see what this is all about?
Old Sep 1, 2002 | 04:30 PM
THEMOOSE's Avatar
That's strange that it mentions it in the trouble shooting guide but not the instructions? It says "not appllcable to pressurized air box models" Do they mean turbos?
Another thing I found is
"Dynojet kits are designed yo use your stock pilot jets.THIS IS A MUST!"
I know a lot of guys here have changed their pilot jets & have had problems.
I have to admit I never paid much more than a glance to the trouble shooting guide because my kit worked fine.
I'm gonna call Dynojet Tues. to see what they say about it.
Nice catch EDD!!
Old Sep 1, 2002 | 05:33 PM
desracers's Avatar
Hey Moose
As you mention not to change the pilot jet of the dynojet. Well on LRD dynojet kit they recommend bump up one size up on the pilot jet. I have never had a problem, It work great.
Also to let you know that Dyno jet made the kit for strictly for LRD for the pipe.
ReconBayou
Oct 31, 2022 05:37 PM
bmxatv10
Oct 14, 2022 06:23 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
black_thunder
Sep 22, 2015 07:59 PM
bvolks
Sep 13, 2015 12:57 PM
