STILL STUCK!!!
Old Jan 14, 2000 | 08:59 PM
eighthmercury's Avatar
I tried replying in my last post, but there was an error.
Anyways, I just wanted to to add that even when I press the clutch, the trans. stays in 3rd(doesn't disengage)
Maybe this will help
Note: this is an addition to my last post stating that my blaster was stuck in 3rd gear, and also, it does have fresh oil.
[This message has been edited by eighthmercury (edited 01-14-2000).]
Old Jan 14, 2000 | 09:58 PM
Blast_Happy's Avatar
So I have to assume that you can't get it started since you can't get it into neutral. Block up the rear wheels and try turning them a little (or rocking the bike forward or backward) while trying to shift down into neutral. These transmissions usually don't shift just sitting still. If it still won't shift the shift drum is stuck/damaged possibly. You can access it from the right side of the engine still in the bike by draining oil and removing the clutch cover. I recommend a good service manual like clymer.
Old Jan 14, 2000 | 11:47 PM
I tryed getting it to roll, and then shift, but it still won't shift. But I doubt my current skill level is good enough to do a job like this. Most of the people in the forum also seem to agree that it is probably the shift drum.
But thanks a lot, I really need all the help I can get
Old Jan 15, 2000 | 11:23 AM
Blastermaster's Avatar
what year is your blaster because if its 2 or 3 years old your clutch might be shoot i was riding on some back yard trails with my frind his 250r made a strang nosie i towed him back to his house we took the cover off and sevral of his clutch plates were broke
[This message has been edited by blastermaster (edited 01-15-2000).]
Old Jan 15, 2000 | 06:21 PM
it's an 89, but most of it has been replaced.
I just sent it to the shop today.I'll tell you what the problem was when I get it back.
Jeff Roper
Feb 1, 2022 11:48 AM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
mrtidy
Feb 3, 2016 05:00 PM
Jackg17
Sep 26, 2015 09:30 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
