why did this happen again
my a arm brok for the 2nd time today the way this happen was i was riding down a trail in like 3rd geer and i hit the front breks and they lokced up and the quad slid to the right and my right upper a arm broke at the 2 welds does anyone know why this happen it is the 2nd time
did you replace it with a new one and it broke also.or did you just weld the first one. Maybe your weld was not right .Ihave had things welded before and they never seem as strong as new.Seems to break right next to weld .Somethings ihave had welded dont break .I think it depends on the person doing the welding.
Well...I have ridden my Blater pretty hard. Jumping, wheelies, etc. I have yet to break an arm off...Bent a few...But they were my own fault...those trees tend to jump right out in front of you.
If you are riding extremely aggressive...then it may be time to think about upgrading the front suspension. That will take some of the hit away from the Arms. Other than that...watch out for those trees.
Unless you are hanging the wheel up on something when you are breaking those A arm's-you are probably just over doing the stock suspension. I've mentioned this(that when things are getting torn up one usually needs more and stiffer suspension, not nessessarily heavier chassis components) before, on the polaris forum.
Sw00p
Sep 24, 2015 02:50 PM
Elkaholic
Sep 6, 2015 02:44 PM
