20 minute ride?
Anyone have any idea why a Yamaha 4 stroke would only run for 20 minutes at a time?
It was not being "pushed hard" and the terrain was semi-flat. It just dies. When I try to re-start it will start for only a second or so, then it dies out like it has run out of gas. It tries to run if you keep it just above an idle but dies out a higher (or lower) RPMs.
I have tried fresh fuel, cleaned the carb, adjusted the valves, and changed the motor oil.
ANY IDEAS? (Thanks).
My friend has a atc 110 and it had pretty much the same problem when we got it back to the house we saw that it had a vacume leak where the air box goes into the carb becouse the bolts had vibrated out. So you might want to check the bolts around the air box and carb.
Ryan Harris yz490 blaster ke100
If it were a car I'd jump on the ignition coil as the likely culprit. It's a classic no brainer for that application. I'd test your coil cold and hot to see if it has a short then if that checks out okay I'd next try the CDI box. If it runs great for 20minutes it is very unlikely that it's a carb problem.
