Extended a-arms
Old Nov 24, 2001 | 11:44 PM
BomBanshee's Avatar
How much do new a-arms cost fr a Raptor and do u need new shocks to use them? Thanks.
Old Nov 25, 2001 | 12:34 AM
TitanRacing25's Avatar
I believe you cna get american star's for 300-400 dollars, and it' a very good idea to get shocks, because after i flipped my front wheels my front shocks wanted to bottom on the stiffest setting, and im sure its worse with ext. a-arms.
Old Nov 25, 2001 | 02:14 PM
IceMan11's Avatar
New A-arms cost between (approx) $350-$1000, depending on what type you get. American Star and Burgard would probably be at the bottom of the scale, Lonestar and Laegar would be at the top. I personally feel you get what you pay for. I'm running a set of TimmyBoys on my Raptor (They run about $650), and I'm very happy with them.
As for shocks, if you're getting extendend a-arms, they would be a very good idea. With extended a-arms, the lower arm has more leverage than the stock arm did, so this will make the stock shock seem very soft. You can adjust the shock a little bit to compensate for this, but it doesn't help a whole lot. Your best solution is to get a new set of shocks for the front (Works, Elka, Axis, PEP, etc).
Ashley S
Feb 18, 2024 08:56 PM
bigred20653
Oct 2, 2015 10:05 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Aug 31, 2015 04:47 AM
XxS0ccerstarxX
Aug 27, 2015 07:40 AM
