winter jetting
Old Dec 10, 2001 | 07:30 PM
DRedd's Avatar
Is it true that jetted engines don't run as well in cold weather? What causes this and how can it be fixed if it is true?
Old Dec 11, 2001 | 12:22 AM
garyhart's Avatar
no they run better because you can make adjustments
when the air is colder more dense, so you getting more air and you need to add more fuel to compensate. no big deal.
Old Dec 11, 2001 | 07:16 PM
Blaster96's Avatar
4-strokes might pop a little and 2-strokes will zing a little more. The cooler air makes the motor run lean a tad. You do not need to change your jet's unless you were running deadly lean in the summer.
ReconBayou
Oct 31, 2022 05:37 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
