12:1 .020 over 660 raptor. what is the new displacement?
Old Jan 10, 2002 | 04:01 PM
jay660Raptor's Avatar
I just had my raptor punched out .020 over w/ a 12:1 compression piston. I know .020 over doesn't make much off a difference, but i dont know how to do the actual math to see the final displacement. If anyone knows the equation or can tell me, it is appreciated.
jay[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jan 10, 2002 | 06:01 PM
ZRWHAT's Avatar
Its just the volume of the cylinder with the stock stroke of 84mm that you are calculating. Here is the equation.
Total Disp.=Area of Piston * Length of Stroke
Total Disp.=(pi*radius^2) * 84mm
Total Disp.=(3.14159*50mm^2) * 84mm
Total Disp.=659.7cm^3 is stock(Convert from mm^3 to cm^3 for CC's move decimel 3 places left)
Convert your 0.020in into mm = 0.508mm So your new diameter is 100.508mm instead of 100mm which is stock. Don't forget to devide by 2 to use in the equation, its the Radius not the diameter.
Hope this helps!
Old Jan 10, 2002 | 06:05 PM
ZRWHAT's Avatar
I guess you've got a 666, sounds F'ing scary to me!
Old Jan 10, 2002 | 06:33 PM
jmc's Avatar
jmc
Here is the simple formula: Bore x Bore x.7854 x Stroke =CC's
Old Jan 10, 2002 | 07:41 PM
raptor720's Avatar
Jay,
What "devil" told you to only go with the .020 666cc?? It is the same $$ to do the 102 and the performance increase is major.
Old Jan 11, 2002 | 12:12 PM
CBUS660R's Avatar
jmc, your "simple formula" doesn't work. All you have done is work backwards to find a false conversion factor that has no application outside of a cylinder with a 100mm bore. If you change the bore, your .7854 conversion factor no longer works. You have to use the formula provided by ZRWHAT to actually figure out displacement for any engine.
Old Jan 11, 2002 | 10:02 PM
scottd's Avatar
I just did it on three different conversions, and it sure works for me.
Old Jan 11, 2002 | 10:46 PM
2000MOJAVE's Avatar
JMC's formula works every way I tried it.
Old Jan 11, 2002 | 11:06 PM
sduncan's Avatar
Try the following: bore x bore x stroke x 3.1416 = displacement. This always worked for me, but then again, math was always my worst subject!!!
Old Jan 12, 2002 | 03:39 AM
jmc's Avatar
jmc
CBUS66R
I think you had better think again.But then what would A.Graham Bell know anyway.100x100x.7854x84=659.736cc.Another eg.100.5x100.5x.7854x84=666.349cc.Do any bore and stroke you like.A retraction would be nice.
