Raptor Problems
Old Jan 12, 2002 | 12:12 AM
Ward660R's Avatar
Hey, yep I'm new here, but I have some problems. First, the starter on my raptor doesn't want to engage again, my dealer fixed it 9 months ago. Is this a problem with Raptors or mine or my dealer. How do I fix it? Second, jetting, can't figure it out no mater how many times I try. I have a FMF PC IV w/ head pipe, pro flo intake w/ foam filter, and no air box lid. The head pipe glows red quickly, puffs a little black smoke, but the plug is fairly white. It also seems a little slugish over the entire range. I live at sea level and have a 155/160 mains and a 22.5 pilot
Old Jan 12, 2002 | 07:05 AM
EDD's Avatar
EDD
ive herd of others having starter problums also.im not sure how to fix it..on the jetting issue you are way lean dont ride it to you fix it,id get a dyno jet jet kit.its simple and you only have to do it once.the kit is 65 to 85.therewebsite address is www.dynojet.com.
hope this helps.
edd
Old Jan 12, 2002 | 09:02 AM
95Warrior's Avatar
No starter problems with mine, but I have heard of a couple of people that had them. I don't know if it was the same problem though. As far as jetting, get a DYNOJET/K&N STAGE 2 kit. Notice the caps, the kit is that important. Just changing the mains will not affect the entire fuel curve, just a portion of it. The Dynojet kit (or K&N Stage 2, same EXACT kit) includes new needles and diaphram springs, which work with the new main jets included to modify the entire fuel curve. Just changing the main jets will leave you lean in the low to mid range, which is why your header is glowing. The cheapest I've seen the kit is www.rockymountain.atv for about $50. I paid $70 from Magic Racing, and am very happy with the results, even with my stock pipe. Like EDD said, with the Dynojet kit, you'll only do it once. Put this jet kit in and you won't believe the difference, especially with your aftermarket pipe. Do it as soon as possible, as running lean is dangerous and can get expensive.
Old Jan 12, 2002 | 11:30 AM
RAPTORAZ's Avatar
Here's what you need for jetting with no airbox lid: 27.5 pilots, needles moved up one notch and 170/175 mains. That should put you real close.
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
