Raptor Leaking Oil
Old Jan 28, 2002 | 04:22 PM
mitchdb's Avatar
My Raptor is leaking oil right behind the front sprocket. Does anyone know what might fix this? Everything looks OK, I hope it's just a little O ring or something simple but I haven't pin pointed anything yet.
Thanks,
Mitch
Old Jan 28, 2002 | 05:28 PM
raptor720's Avatar
Check the breather and oil level before you go into the seal.
Old Jan 28, 2002 | 05:40 PM
NotuRaptor's Avatar
I had the same problem. Mine was the seal Raptor720 mentions. I also opted to replace the metal bushing that it seals against since it had a groove worn into it.
I ordered my parts from Riva Yamaha but for the life of me, I couldn't find the right page under the parts finder for you. If you can't find them, post back and I will find the invoice and provide the part numbers.
/NotuRaptor
Old Jan 28, 2002 | 05:43 PM
mitchdb's Avatar
What will that do? (checking the breather and oil level)
Is the seal easy to get to or do I have to take the motor apart? Is it the little O ring that the metal cup sits on (the one behind the sprocket itself)?
Thanks
Old Jan 28, 2002 | 06:59 PM
NotuRaptor's Avatar
Yep, take the sprocket off and then the next piece you mention. It is right there. It is a really easy process.
/NotuRaptor
Old Jan 29, 2002 | 10:24 AM
mitchdb's Avatar
Cool, thanks a lot!
.....just to make sure. It's the little O ring on the shaft, right?
Thanks,
Mitch
bmxatv10
Oct 14, 2022 06:23 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
