Is it true the Raptor's engine has a valve/seat durability problem??
Old Jan 29, 2002 | 10:05 PM
scottd's Avatar
I think it was Mickey Dunlap @ FST that said that any Raptor with over 10 hrs. on the engine would be experiencing valve problems...specifically "mushrooming" of the valve face. (supposedly due to weak stock valve springs?) Has anyone heard of this? Has anyone had ANY valve problems on their stock Raptor engines, or have any reason to believe that this rumor is true? I hope all this stuff is not the case....but would sure like some feedback on what you guys have seen or experienced. Thanks!!! P.S. IF there is a problem, what is the fix?
Old Jan 29, 2002 | 10:34 PM
THEMOOSE's Avatar
While I was at my dealership today (M&W Powersports Broken Arrow OK) getting A oil filter I asked them about any problems they had noticed with Raptors. They said the only work they have done were Valve ajd,adding pipes & rejetting ,crash damage & replacing bent axles (3). No trannys no starters no valve problems. This is only one dealer in one area so take it for what its worth but they have sold a lot of Raptors.
Old Jan 30, 2002 | 12:02 AM
raptor720's Avatar
If Mickey has seen valve issues I suspect they are true. He does provide some good tech info from time to time.
I have seen some valve sealing problems in addition to valve guide clearance problems and oil leaking into the intake system from the guides.
I replace the seats, valves and install new guides so it is a non-issue for me.
AtvManiac78
Jul 11, 2015 03:20 AM
DTroyer01
Jul 3, 2015 07:34 AM
Schneider
Jun 4, 2015 11:37 AM
kevbowe
Jun 1, 2015 01:17 AM
RaptorGuy01
Oct 31, 2000 04:23 AM
